Salta al contenuto principale
HTC One X Plus Top Speaker Replacement
Cosa ti serve
  1. HTC One X Plus Top Speaker Replacement, Top Speaker: passo 1, immagine 1 di 1
    • Hold down the power button to turn off your device.
    • Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
    • The SIM card slot is located on the top edge of the device.
  2. HTC One X Plus Top Speaker Replacement: passo 2, immagine 1 di 3 HTC One X Plus Top Speaker Replacement: passo 2, immagine 2 di 3 HTC One X Plus Top Speaker Replacement: passo 2, immagine 3 di 3
    • Using plastic opening tools, pry open the bottom of the device.
    • You will hear clicking sounds as the sides of the device detach from the screen.
    • Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
  3. HTC One X Plus Top Speaker Replacement: passo 3, immagine 1 di 3 HTC One X Plus Top Speaker Replacement: passo 3, immagine 2 di 3 HTC One X Plus Top Speaker Replacement: passo 3, immagine 3 di 3
    • Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
    • Once you have disassembled your device the warranty will no longer be valid.
  4. HTC One X Plus Top Speaker Replacement: passo 4, immagine 1 di 3 HTC One X Plus Top Speaker Replacement: passo 4, immagine 2 di 3 HTC One X Plus Top Speaker Replacement: passo 4, immagine 3 di 3
    • Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
    • These are two 3.4mm Philips head screws found in the lower right corner of the phone.
  5. HTC One X Plus Top Speaker Replacement: passo 5, immagine 1 di 2 HTC One X Plus Top Speaker Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull out the power button flex cable using tweezers to disconnect from the phone.
    • Use the tweezers to then disconnect the touch screen flex cable.
  6. HTC One X Plus Top Speaker Replacement: passo 6, immagine 1 di 3 HTC One X Plus Top Speaker Replacement: passo 6, immagine 2 di 3 HTC One X Plus Top Speaker Replacement: passo 6, immagine 3 di 3
    • Remove the battery connections to the logic board.
    • This is the six pin connector seen in the red box.
    • Pull the battery away to remove from the back of the screen.
  7. HTC One X Plus Top Speaker Replacement: passo 7, immagine 1 di 2 HTC One X Plus Top Speaker Replacement: passo 7, immagine 2 di 2
    • CAUTION: carefully remove the top speaker from the phone using tweezers.
Conclusione
Jason Melo
Membro da: 08/26/15
483 Reputazione
4 Guide realizzate
USF Tampa, Team 3-3, Eyestone Fall 2015 Membro di USF Tampa, Team 3-3, Eyestone Fall 2015
USFT-EYESTONE-F15S3G3
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 430
