Introduzione
This guide will take you through the process of replacing the screen on the HTC One Remix.
Insert the SIM card eject tool or a paperclip into the small hole nest to the SIM card tray, located on the upper left hand side of the phone.
  • Insert the SIM card eject tool or a paperclip into the small hole nest to the SIM card tray, located on the upper left hand side of the phone.
  • Press to eject the tray.
  • This may require significant amount of force.
Aggiungi Commento
Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
  • Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
  • iOpener Instructions
Aggiungi Commento
  • Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
  • The top is glued on so it may be difficult to get off.
Aggiungi Commento
  • Carefully lift the full screen away from the frame.
  • Using an exactoknife, cut the ribbon wires on the bottom left corner of the screen.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 33
