Salta al contenuto principale
HTC One Mini Rear Facing Camera Replacement
Cosa ti serve
  1. HTC One Mini Rear Facing Camera Replacement, iOpener Heating: passo 1, immagine 1 di 1
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  2. HTC One Mini Rear Facing Camera Replacement, Remove Speaker Grills: passo 2, immagine 1 di 1
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
  3. HTC One Mini Rear Facing Camera Replacement, Remove Screw: passo 3, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screw: passo 3, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screw: passo 3, immagine 3 di 3
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
  4. HTC One Mini Rear Facing Camera Replacement: passo 4, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement: passo 4, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement: passo 4, immagine 3 di 3
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  5. HTC One Mini Rear Facing Camera Replacement, Separate Rear Case: passo 5, immagine 1 di 2 HTC One Mini Rear Facing Camera Replacement, Separate Rear Case: passo 5, immagine 2 di 2
    • Remove the rear case from the phone.
  6. HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 6, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 6, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 6, immagine 3 di 3
    • Remove the two Phillips screws securing the battery connector.
  7. HTC One Mini Rear Facing Camera Replacement: passo 7, immagine 1 di 2 HTC One Mini Rear Facing Camera Replacement: passo 7, immagine 2 di 2
    • Disconnect the battery by prying the metal cover straight up.
  8. HTC One Mini Rear Facing Camera Replacement, Remove screws: passo 8, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement, Remove screws: passo 8, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement, Remove screws: passo 8, immagine 3 di 3
    • Remove two Phillips screws.
    • The screw on the upper right corner secures a tiny golden washer. Remove this washer.
  9. HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 9, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 9, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 9, immagine 3 di 3
    • Remove the two small black Phillips screws.
  10. HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 10, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 10, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement, Remove Screws: passo 10, immagine 3 di 3
    • Remove two more Phillips screws.
  11. HTC One Mini Rear Facing Camera Replacement, Remove protective foil.: passo 11, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement, Remove protective foil.: passo 11, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement, Remove protective foil.: passo 11, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
  12. HTC One Mini Rear Facing Camera Replacement: passo 12, immagine 1 di 2 HTC One Mini Rear Facing Camera Replacement: passo 12, immagine 2 di 2
    • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
    • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
  13. HTC One Mini Rear Facing Camera Replacement: passo 13, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement: passo 13, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement: passo 13, immagine 3 di 3
    • Peel off the silver strip with your tweezers.
    • Using your hands, detach the black strip from the board without removing it.
  14. HTC One Mini Rear Facing Camera Replacement: passo 14, immagine 1 di 2 HTC One Mini Rear Facing Camera Replacement: passo 14, immagine 2 di 2
    • Detach carefully with your tweezers the volume buttons.
    • Detach the power button with your tweezers.
  15. HTC One Mini Rear Facing Camera Replacement: passo 15, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement: passo 15, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement: passo 15, immagine 3 di 3
    • Identify the screw behind the cable.
    • Remove the screw using a Phillips screwdriver.
  16. HTC One Mini Rear Facing Camera Replacement: passo 16, immagine 1 di 2 HTC One Mini Rear Facing Camera Replacement: passo 16, immagine 2 di 2
    • Lift the motherboard, but don't try to remove it completely yet.
    • Handle the board only by the edges.
  17. HTC One Mini Rear Facing Camera Replacement: passo 17, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement: passo 17, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement: passo 17, immagine 3 di 3
    • Using your tweezers, remove the black square located in the power button.
    • Remove the motherboard completely.
  18. HTC One Mini Rear Facing Camera Replacement, Rear Facing Camera: passo 18, immagine 1 di 1
    • Remove the motherboard and place it so that the rear camera is face down.
  19. HTC One Mini Rear Facing Camera Replacement: passo 19, immagine 1 di 1
    Compra
    • Use the tweezers to carefully peel back the copper tape attached to your rear camera.
  20. HTC One Mini Rear Facing Camera Replacement: passo 20, immagine 1 di 3 HTC One Mini Rear Facing Camera Replacement: passo 20, immagine 2 di 3 HTC One Mini Rear Facing Camera Replacement: passo 20, immagine 3 di 3
    • Use the tweezers to lift the hatch and remove the part of the rear camera that is inserted.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 3-4, Brown Fall 2014 Membro di USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 Membri
10 Guide realizzate
2 Commenti
What glue does one use when putting back the speaker grill?
Ratfink - Replica
where can I get the rear camera? what is te number part. tks
Sinuhe Less - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,055
