Salta al contenuto principale
HTC One Mini 2 Back Plate Replacement
Cosa ti serve
  1. HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: passo 1, immagine 1 di 3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: passo 1, immagine 2 di 3 HTC One Mini 2 Back Plate Replacement, Sim and MicroSD Card: passo 1, immagine 3 di 3
    • Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
    • Set the cardholders aside.
  2. HTC One Mini 2 Back Plate Replacement: passo 2, immagine 1 di 1
    • Heat up the top grey speaker plate with the iFixit iOpener for two minutes.
  3. HTC One Mini 2 Back Plate Replacement, Front Plate: passo 3, immagine 1 di 3 HTC One Mini 2 Back Plate Replacement, Front Plate: passo 3, immagine 2 di 3 HTC One Mini 2 Back Plate Replacement, Front Plate: passo 3, immagine 3 di 3
    • Use a metal spudger to pry up the left edge of the upper grey front plate.
    • Place the spudger between the inside white plastic edge and the grey plate. Do not pry between the two white plastic frames.
    • Don’t pry against the glass. Pry against only the left side as there is a delicate antenna under the plate.
    • Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
  4. HTC One Mini 2 Back Plate Replacement: passo 4, immagine 1 di 2 HTC One Mini 2 Back Plate Replacement: passo 4, immagine 2 di 2
    • Remove the 2mm screw with a T5 torx screwdriver head from the iFixit tool kit.
  5. HTC One Mini 2 Back Plate Replacement: passo 5, immagine 1 di 2 HTC One Mini 2 Back Plate Replacement: passo 5, immagine 2 di 2
    • Use the plastic pry tool to pry around the edge of the phone.
    • Pry carefully around the card slots.
    • Slowly pull up from the right side of the screen like opening a book.
    • The plastic piece for the power button may fall out. Set it aside for reassembly.
    • Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 4-48, Amido Fall 2014 Membro di Cal Poly, Team 4-48, Amido Fall 2014
CPSU-AMIDO-F14S4G48
5 Membri
17 Guide realizzate
Un commento
what is the black ribbon antenna on the front
deancvijic90 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 16
Tutti i Tempi: 10,303
