Introduzione
In this guide you willl learn how to replace a microphone in a HTC One Max.
Cosa ti serve
Lift back cover while pressing highlighted release switch towards the center of the phone.
Remove the two 2.2 mm Phillips #000 screws holding the battery cable.
Use a plastic tool to remove the ribbon cable.
Remove the tape covering three flex cable gate connectors on the bottom left side of the phone.
Use small plastic opening tool to pry open the latch on each of these gate connectors to disconnect the three cables.
Remove the three 3 mm Phillips #000 screws from the secondary board at the top.
Remove two screws from the bottom.
Set aside metal retaining plate.
Pry the battery away from the back of the screen with a plastic tool.
Altre 15 persone hanno completato questa guida.
4 Commenti
Microphone in the article, battery in the title.
How to change LCD screen for this model?
