Salta al contenuto principale
HTC One M9 Rear Case Replacement
Cosa ti serve
  1. HTC One M9 Rear Case Replacement, SIM Card: passo 1, immagine 1 di 3 HTC One M9 Rear Case Replacement, SIM Card: passo 1, immagine 2 di 3 HTC One M9 Rear Case Replacement, SIM Card: passo 1, immagine 3 di 3
    • Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
    • Press to eject the tray.
    • This may require a significant amount of force.
    • When reinserting the SIM card, ensure that its contacts are facing to the rear side. The tapered corner of the SIM card has to point to the outer bottom corner of the tray.
  2. HTC One M9 Rear Case Replacement, MicroSD Card: passo 2, immagine 1 di 3 HTC One M9 Rear Case Replacement, MicroSD Card: passo 2, immagine 2 di 3 HTC One M9 Rear Case Replacement, MicroSD Card: passo 2, immagine 3 di 3
    • The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
    • Then press the tool or paperclip to eject the microSD card tray.
    • When reinserting the microSD card, ensure that it is in the correct orientation to the tray. The electrical connectors should be inserted first, with the microSD card face up.
    • It is normal for the microSD to sit imperfectly in the tray. The microSD card is easy to reposition within the tray.
  3. HTC One M9 Rear Case Replacement, Rear Case: passo 3, immagine 1 di 3 HTC One M9 Rear Case Replacement, Rear Case: passo 3, immagine 2 di 3 HTC One M9 Rear Case Replacement, Rear Case: passo 3, immagine 3 di 3
    • Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
    • Remove the two 4 mm T5 Torx screws on the top of the case.
    Be sure to remove the SIM tray and memory card tray prior to removing back case! Bent mine because that step was missing.
    cameronb - Replica
    The black plastic piece that runs across the top is very thin and is stuck on with very strong tape.
    SMcC21985 - Replica
  4. HTC One M9 Rear Case Replacement: passo 4, immagine 1 di 3 HTC One M9 Rear Case Replacement: passo 4, immagine 2 di 3 HTC One M9 Rear Case Replacement: passo 4, immagine 3 di 3
    • Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
    • The SIM card tray and Micro SD card tray must be removed before the back cover can be removed.
    • Be careful around the power and volume buttons, as they are fairly delicate.
    • Be careful when separating the body from the display assembly, as the rear-facing camera may be stuck to the body with adhesive.
    The SIM Card and SD Card's need to be removed before the case will come apart.
    Andrew Froude - Replica
    I found a video showing someone using a 2 to 3 inch length scraper razor blade around the perimeter. On my second HTCM9 battery swap I found that leading with a square tipped X-Acto blade to begin the opening, and leaving the trailing, “already opened” gap “wedged” open with the scraper blade helped smoothly open from top (IR header) to bottom (micro USB charger port). A conventional spudger pries open too quickly and can damage and misshape the LCD’s soft bezel. The bezel surround is a much softer compound than the rear case. You can work the rear case loose by gently prying the back’s perimeter outward and occasionally inward as you progress. There are four tabs on the LCD assembly (i.e. nearby and under the pliers in step 5) on each side that protrude into the rear case. Push in toward the back, and pry outward on the back case seam around the vicinity of the tabs. This action provides clearance for the tab to loose from the case tab slot.
    Michael K - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
89.934 Reputazione
89 Guide realizzate
4 Commenti
Great guide, changed my backcover in under 5 minutes. Thank you!
Philippe Cambien - Replica
Cannot snap in the cover at the bottom. Afraid to force it a break screen. Please, help.
Sharescience - Replica
Take the case off, bend the little plastic lugs gently out, put the back on starting from the bottom
Adrian Jenkins -
hi guys!
does any one know how to get the back cover of my htc one m9
pollo_s - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 8,611
