Introduzione
Users of this guide will be able to remove the connections from the motherboard to gain access to their battery. This repair is much more difficult compared to other phones' battery replacements. Be careful not to damage any other components during the repair.
Insert a microSD card eject tool or a paperclip into the small hole in the microSD card tray, located on the upper right hand side of the phone above the volume buttons.
Press to eject the tray.
Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
Remove the two 4 mm T5 Torx screws on the top of the case.
Use a pair of tweezers to get underneath the white and blue cable connectors and gently push them upwards to disconnect them.
Use a pair of tweezers to lift the vibrator out of its crevace.
Use an iOpener or heat gun to loosen the adhesive at the bottom of the motherboard.
Use a plastic opening tool or a spudger to gently pry the motherboard out of the case along the edges.
Then, gently lift the motherboard beginning from the top corner first (near the camera).
Using tweezers, remove the tape from the bottom of the battery.
Use a spudger to carefully pry the battery up from the display assembly.
Altre 41 persone hanno completato questa guida.
19 Commenti
I replaced the battery now but encountered a problem, as my phone wasn't working properly afterwards. When I switched on, it kind of reset to default and the play store app kept crashing, so I had to do a factory reset
Done all of this by the book but phone won't turn on charge screen lights up and charges but still won't turn on please help
You tore the power and volume button cable. It's a $10 replacement, no big deal. I did the same thing even after having repaired phones for years now.
Jonah -
