Salta al contenuto principale
HTC Maple 100 Front Panel Replacement
Cosa ti serve
  1. HTC Maple 100 Front Panel Replacement, Battery: passo 1, immagine 1 di 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Front Panel Replacement: passo 2, immagine 1 di 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Front Panel Replacement: passo 3, immagine 1 di 2 HTC Maple 100 Front Panel Replacement: passo 3, immagine 2 di 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Front Panel Replacement, Back Panel: passo 4, immagine 1 di 2 HTC Maple 100 Front Panel Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Front Panel Replacement: passo 5, immagine 1 di 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Front Panel Replacement: passo 6, immagine 1 di 3 HTC Maple 100 Front Panel Replacement: passo 6, immagine 2 di 3 HTC Maple 100 Front Panel Replacement: passo 6, immagine 3 di 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
  7. HTC Maple 100 Front Panel Replacement, Motherboard: passo 7, immagine 1 di 2 HTC Maple 100 Front Panel Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the one 3.3mm Phillips #00 screw.
  8. HTC Maple 100 Front Panel Replacement: passo 8, immagine 1 di 2 HTC Maple 100 Front Panel Replacement: passo 8, immagine 2 di 2
    • Use your finger or the plastic opening tool to unclip the board.
    • Be aware of the ribbon cable connected to the motherboard inside the phone.
  9. HTC Maple 100 Front Panel Replacement: passo 9, immagine 1 di 2 HTC Maple 100 Front Panel Replacement: passo 9, immagine 2 di 2
    • Peel off the yellow piece of tape from the phone.
  10. HTC Maple 100 Front Panel Replacement: passo 10, immagine 1 di 3 HTC Maple 100 Front Panel Replacement: passo 10, immagine 2 di 3 HTC Maple 100 Front Panel Replacement: passo 10, immagine 3 di 3
    • Flip up the retaining flap with your fingernail or a plastic opening tool.
    • Pull on the ribbon cable gently with your fingers.
  11. HTC Maple 100 Front Panel Replacement: passo 11, immagine 1 di 2 HTC Maple 100 Front Panel Replacement: passo 11, immagine 2 di 2
    • Split apart the motherboard and front panel.
    • Remove the other yellow piece of tape off of the end of the ribbon cable.
  12. HTC Maple 100 Front Panel Replacement: passo 12, immagine 1 di 2 HTC Maple 100 Front Panel Replacement: passo 12, immagine 2 di 2
    • Gently pull on the ribbon cable to separate the motherboard.
  13. HTC Maple 100 Front Panel Replacement, Keyboard: passo 13, immagine 1 di 2 HTC Maple 100 Front Panel Replacement, Keyboard: passo 13, immagine 2 di 2
    • Remove the four 1.9 mm Phillips #00 screws.
  14. HTC Maple 100 Front Panel Replacement: passo 14, immagine 1 di 1
    • Peel back the tape gently.
  15. HTC Maple 100 Front Panel Replacement: passo 15, immagine 1 di 1
    • Remove the board gently.
  16. HTC Maple 100 Front Panel Replacement: passo 16, immagine 1 di 2 HTC Maple 100 Front Panel Replacement: passo 16, immagine 2 di 2
    • Remove the keys carefully.
  17. HTC Maple 100 Front Panel Replacement, Front Panel: passo 17, immagine 1 di 3 HTC Maple 100 Front Panel Replacement, Front Panel: passo 17, immagine 2 di 3 HTC Maple 100 Front Panel Replacement, Front Panel: passo 17, immagine 3 di 3
    • Using the Plastic Opening Tool, pry out the LCD screen and remove with fingers.
    • Be gentle because the LCD screen is fragile.
  18. HTC Maple 100 Front Panel Replacement: passo 18, immagine 1 di 3 HTC Maple 100 Front Panel Replacement: passo 18, immagine 2 di 3 HTC Maple 100 Front Panel Replacement: passo 18, immagine 3 di 3
    • Use the Plastic Opening Tool to remove the internal ear speaker.
Conclusione
Cal Poly, Team 20-29, Maness Fall 2011 Membro di Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Membri
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 839
