Salta al contenuto principale
HTC Maple 100 Back Panel Replacement
Cosa ti serve
  1. HTC Maple 100 Back Panel Replacement, Battery: passo 1, immagine 1 di 1
    • First remove the back cover of your phone to expose the battery.
  2. HTC Maple 100 Back Panel Replacement: passo 2, immagine 1 di 1
    • Turn the phone over.
    • Push forward on the battery with your thumb.
  3. HTC Maple 100 Back Panel Replacement: passo 3, immagine 1 di 2 HTC Maple 100 Back Panel Replacement: passo 3, immagine 2 di 2
    • Take the battery out by lifting it upwards.
    • When reassembling, make sure that the battery contacts match up.
  4. HTC Maple 100 Back Panel Replacement, Back Panel: passo 4, immagine 1 di 2 HTC Maple 100 Back Panel Replacement, Back Panel: passo 4, immagine 2 di 2
    • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
  5. HTC Maple 100 Back Panel Replacement: passo 5, immagine 1 di 1
    • Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
  6. HTC Maple 100 Back Panel Replacement: passo 6, immagine 1 di 3 HTC Maple 100 Back Panel Replacement: passo 6, immagine 2 di 3 HTC Maple 100 Back Panel Replacement: passo 6, immagine 3 di 3
    • Insert the plastic opening tool along the seams at different points to it pry the clips off.
    • This may require a bit of force. The USB port cover may fall off in this step.
Conclusione
Cal Poly, Team 20-29, Maness Fall 2011 Membro di Cal Poly, Team 20-29, Maness Fall 2011
CPSU-MANESS-F11S20G29
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 774
