Introduzione
This is not a pleasant repair. The device is full of adhesive. Removing the display assembly from front panel (or "mid chassis") can easily result in the destruction of the front panel bezel and digitizer. I suggest that you replace the entire digitizer, rather than one portion. If you want a beautiful front panel bezel, you will definitely need to replace that part, as well.
Cosa ti serve
Remove battery cover using a plastic opening tool or finger nail.
Slide opening tool to release clasps and remove battery cover.
Blast the front panel with heat and pry between the display assembly and front panel bezel, working one or several guitar picks around the display assembly.
Once the display assembly is loosened from the front panel, it will fall away.
The front glass came off easily, but the digitizer was much more difficult to remove. The adhesive holding together the display assembly is much weaker than the adhesive holding the display assembly to the front panel.
Altre 17 persone hanno completato questa guida.
