Salta al contenuto principale
HTC Fortress Camera Replacement
Cosa ti serve
  1. HTC Fortress Camera Replacement, Battery: passo 1, immagine 1 di 2 HTC Fortress Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover of the device by sliding it upward.
    • You may need to remove the phone stylus first.
  2. HTC Fortress Camera Replacement: passo 2, immagine 1 di 2 HTC Fortress Camera Replacement: passo 2, immagine 2 di 2
    • Remove the battery by pulling it away from the back of the phone.
  3. HTC Fortress Camera Replacement, Camera: passo 3, immagine 1 di 2 HTC Fortress Camera Replacement, Camera: passo 3, immagine 2 di 2
    • Remove the top 2 screws on the back of the phone with the T4 Screwdriver.
  4. HTC Fortress Camera Replacement: passo 4, immagine 1 di 3 HTC Fortress Camera Replacement: passo 4, immagine 2 di 3 HTC Fortress Camera Replacement: passo 4, immagine 3 di 3
    • Remove the camera panel by hand (black cover above the battery slot).
    • Be careful; there is a cable attached underneath the case. It does detach, just pull on it carefully.
    • During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
  5. HTC Fortress Camera Replacement: passo 5, immagine 1 di 3 HTC Fortress Camera Replacement: passo 5, immagine 2 di 3 HTC Fortress Camera Replacement: passo 5, immagine 3 di 3
    • Work the metal camera casing off by slowly prying up the sides using the spudger.
  6. HTC Fortress Camera Replacement: passo 6, immagine 1 di 2 HTC Fortress Camera Replacement: passo 6, immagine 2 di 2
    • Use the tweezers to pull the camera straight out of the phone.
Conclusione
Lucas David
Membro da: 04/19/13
540 Reputazione
9 Guide realizzate
Cal Poly, Team 4-13, Maness Spring 2013 Membro di Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 382
