Salta al contenuto principale
HTC Flyer MicroUSB Port Replacement
Cosa ti serve
  1. HTC Flyer MicroUSB Port Replacement, Back Cover: passo 1, immagine 1 di 3 HTC Flyer MicroUSB Port Replacement, Back Cover: passo 1, immagine 2 di 3 HTC Flyer MicroUSB Port Replacement, Back Cover: passo 1, immagine 3 di 3
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer MicroUSB Port Replacement: passo 2, immagine 1 di 3 HTC Flyer MicroUSB Port Replacement: passo 2, immagine 2 di 3 HTC Flyer MicroUSB Port Replacement: passo 2, immagine 3 di 3
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer MicroUSB Port Replacement: passo 3, immagine 1 di 3 HTC Flyer MicroUSB Port Replacement: passo 3, immagine 2 di 3 HTC Flyer MicroUSB Port Replacement: passo 3, immagine 3 di 3
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer MicroUSB Port Replacement: passo 4, immagine 1 di 2 HTC Flyer MicroUSB Port Replacement: passo 4, immagine 2 di 2
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
  5. HTC Flyer MicroUSB Port Replacement, Battery: passo 5, immagine 1 di 2 HTC Flyer MicroUSB Port Replacement, Battery: passo 5, immagine 2 di 2
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
  6. HTC Flyer MicroUSB Port Replacement: passo 6, immagine 1 di 3 HTC Flyer MicroUSB Port Replacement: passo 6, immagine 2 di 3 HTC Flyer MicroUSB Port Replacement: passo 6, immagine 3 di 3
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
  7. HTC Flyer MicroUSB Port Replacement: passo 7, immagine 1 di 1
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
  8. HTC Flyer MicroUSB Port Replacement: passo 8, immagine 1 di 3 HTC Flyer MicroUSB Port Replacement: passo 8, immagine 2 di 3 HTC Flyer MicroUSB Port Replacement: passo 8, immagine 3 di 3
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
  9. HTC Flyer MicroUSB Port Replacement, MicroUSB Port: passo 9, immagine 1 di 1
    • Use a spudger to unclip the the wires attached to the power jack
    • The clips have a white or black relief tab that, when pressed, releases the wires.
  10. HTC Flyer MicroUSB Port Replacement: passo 10, immagine 1 di 2 HTC Flyer MicroUSB Port Replacement: passo 10, immagine 2 di 2
    • Remove the two 2.5mm Torx T5 screws from both sides of the power jack panel.
  11. HTC Flyer MicroUSB Port Replacement: passo 11, immagine 1 di 2 HTC Flyer MicroUSB Port Replacement: passo 11, immagine 2 di 2
    • Gently remove the power jack panel.
Conclusione
Altre 4 persone hanno completato questa guida.
Joshua
Membro da: 10/07/14
185 Reputazione
1 Guida realizzata
USF Tampa, Team 8-5, Leahy Fall 2014 Membro di USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,170
