Salta al contenuto principale
HTC Flyer Charging Port Replacement
Cosa ti serve
  1. HTC Flyer Charging Port Replacement, Charging Port: passo 1, immagine 1 di 1
    • Remove the white portion of the top cover as shown. Push down on it to slide it off using just your fingers. Be careful not to break the clips holding it in place with removing it.
  2. HTC Flyer Charging Port Replacement: passo 2, immagine 1 di 3 HTC Flyer Charging Port Replacement: passo 2, immagine 2 di 3 HTC Flyer Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove the five Torx T5 screws.
  3. HTC Flyer Charging Port Replacement: passo 3, immagine 1 di 2 HTC Flyer Charging Port Replacement: passo 3, immagine 2 di 2
    • Remove full frame on the back. A tip is to tape the volume button to the frame before removing it, as the volume button will fall out.
  4. HTC Flyer Charging Port Replacement: passo 4, immagine 1 di 2 HTC Flyer Charging Port Replacement: passo 4, immagine 2 di 2
    • Remove the plastic top cover of the motherboard.
  5. HTC Flyer Charging Port Replacement: passo 5, immagine 1 di 2 HTC Flyer Charging Port Replacement: passo 5, immagine 2 di 2
    • Remove four T5 Torx screws.
  6. HTC Flyer Charging Port Replacement: passo 6, immagine 1 di 3 HTC Flyer Charging Port Replacement: passo 6, immagine 2 di 3 HTC Flyer Charging Port Replacement: passo 6, immagine 3 di 3
    • Remove twelve of the connectors.
  7. HTC Flyer Charging Port Replacement: passo 7, immagine 1 di 2 HTC Flyer Charging Port Replacement: passo 7, immagine 2 di 2
    • Release the flex-screen touch cable. It is held in place with clips. Use the safe open pry tool to unclip it. Note that it will still be connected to the base and the motherboard.
  8. HTC Flyer Charging Port Replacement: passo 8, immagine 1 di 1
    • Flip the motherboard and the flex screen to the left.
  9. HTC Flyer Charging Port Replacement: passo 9, immagine 1 di 1
    • Release the two file cables attached to the motherboard.
  10. HTC Flyer Charging Port Replacement: passo 10, immagine 1 di 1
    • Remove the motherboard. Note that the flex screen will not be removed with it and will remain attached to the tablet frame.
  11. HTC Flyer Charging Port Replacement: passo 11, immagine 1 di 3 HTC Flyer Charging Port Replacement: passo 11, immagine 2 di 3 HTC Flyer Charging Port Replacement: passo 11, immagine 3 di 3
  12. HTC Flyer Charging Port Replacement: passo 12, immagine 1 di 2 HTC Flyer Charging Port Replacement: passo 12, immagine 2 di 2
    • Remove the dock port flex cable. It will be tangled around other cables, so take care not to rip it while removing.
Conclusione
Joshua Mahon
Membro da: 11/26/18
445 Reputazione
3 Guide realizzate
IUPUI, Team S5-G5, Wilson Fall 2018 Membro di IUPUI, Team S5-G5, Wilson Fall 2018
IUPUI-WILSON-F18S5G5
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 363
