Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Remove the rear inner frame to gain access to the internals of the HTC Evo 4G.
  1. Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. Lift the rear panel off of the inner rear frame.
    • Lift the rear panel off of the inner rear frame.
  3. Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
  7. Remove six T5 Torx screws securing the rear inner frame to the inner case.
    • Remove six T5 Torx screws securing the rear inner frame to the inner case.
  8. Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
  9. Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo. Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
    • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
  10. Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo. Pry up the rear inner frame along the right edge using the method described in previous steps. Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
    • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
    • Pry up the rear inner frame along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
  11. Remove the rear inner frame from the rest of the Evo.
    • Remove the rear inner frame from the rest of the Evo.
Conclusione
Altre 9 persone hanno completato questa guida.
You may want people to also know they have to remove the lcd panel and the rear speaker to install them in their new rear inner panel.
Tony Stone - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 11,934
