Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
  • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
Aggiungi Commento
Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
  • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
Aggiungi Commento
  • When open, pull on “Open” tab and it should rotate towards you
  • Grab the bottom edge of the battery and pull it toward you
Aggiungi Commento
  • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
  • Info*: The adhesive tape that you may find will not be necessary for replacement later
Aggiungi Commento
  • Remove the two Phillips screws to release the casing above the port
  • Remove the top and bottom pairs of Torx screws.
  • Remove the middle pair of two Phillips screws.
Aggiungi Commento
  • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
Aggiungi Commento
  • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
Aggiungi Commento
  • Remove the rear housing by prying around the edge with your Safety Pry Tool
Aggiungi Commento
  • Unplug the wire connecting the vibrator to the board with your tweezers
Aggiungi Commento
  • Unfold motherboard from the screen (open carefully like a book)
Aggiungi Commento
  • Disconnect the two aluminum flex cables
Aggiungi Commento
  • The flex cables should be the only binding and after being removed should leave you with the separate screen
Aggiungi Commento
Conclusione
Replace the screen and to reassemble your device, follow these instructions in reverse order.
Victoria
Membro da: 23/10/2014
94 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 473
