1. Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
    • Tools Needed: 1. Safety pry tool (guitar pick), 2. Tweezers, 3. Phillips Screwdriver, 4. Star tip Precision Screwdriver, 5. Flathead Screwdriver
  2. Use your safety pry tool on the outside edges of the back casing to lift and remove it Use your safety pry tool on the outside edges of the back casing to lift and remove it Use your safety pry tool on the outside edges of the back casing to lift and remove it
    • Use your safety pry tool on the outside edges of the back casing to lift and remove it
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
  4. Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
    • Take your flathead and stick it into the holes to the left of the lens and carefully work your way around the perimeter pushing up the lens until it snaps off
  5. Remove old lens. Place replacement lens over the camera lens and it should loosely snap on
    • Remove old lens.
    • Place replacement lens over the camera lens and it should loosely snap on
    • Info*: Don’t worry if the cover is loose because the cover of the phone would hold it in place
  6. Snap the cover back into place
    • Snap the cover back into place
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Victoria
Membro da: 23/10/2014
94 Reputazione
3 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 260
