Introduzione
This guide will walk you through the steps necessary to access the power button on your HTC Evo 4G for replacement. The four steps require no special skills. There are small parts that could get lost easily upon removal if not handled carefully.
  1. Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  2. Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
    • Remove the six screws on the back of your phone with the T5 screwdriver. Be careful not to lose the screws.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone. Lift off the inner frame from the rest of the phone to remove it. Lift off the inner frame from the rest of the phone to remove it.
    • Use the plastic opening tool to gently pry the inner frame apart from the rest of the phone.
    • Lift off the inner frame from the rest of the phone to remove it.
  5. Carefully remove the power button located at the top of the phone Carefully remove the power button located at the top of the phone
    • Carefully remove the power button located at the top of the phone
Conclusione
Sage Jurado
Membro da: 13/03/2014
864 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 438
