Introduzione
Use this guide to replace the Dual LED Flash in your Droid Incredible.
Strumenti
Ricambi
Nessuna parte specificata.
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Press the MicroSD card further into its slot until it clicks.
Release the MicroSD card, and it will pop out slightly.
Remove four T6 Torx screws securing the rear inner frame to the front case.
Remove two #000 Phillips screws attaching the Dual LED Flash board to the Rear Inner Frame.
