Salta al contenuto principale
HTC Droid Incredible Dual LED FLash Replacement
Cosa ti serve
  1. HTC Droid Incredible Dual LED FLash Replacement, Battery: passo 1, immagine 1 di 3 HTC Droid Incredible Dual LED FLash Replacement, Battery: passo 1, immagine 2 di 3 HTC Droid Incredible Dual LED FLash Replacement, Battery: passo 1, immagine 3 di 3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Dual LED FLash Replacement: passo 2, immagine 1 di 1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Dual LED FLash Replacement: passo 3, immagine 1 di 3 HTC Droid Incredible Dual LED FLash Replacement: passo 3, immagine 2 di 3 HTC Droid Incredible Dual LED FLash Replacement: passo 3, immagine 3 di 3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. HTC Droid Incredible Dual LED FLash Replacement, MicroSD card: passo 4, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement, MicroSD card: passo 4, immagine 2 di 2
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. HTC Droid Incredible Dual LED FLash Replacement: passo 5, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement: passo 5, immagine 2 di 2
    • Pull the MicroSD card straight out of its slot.
  6. HTC Droid Incredible Dual LED FLash Replacement, Rear Inner Frame: passo 6, immagine 1 di 1
    • Remove four T6 Torx screws securing the rear inner frame to the front case.
  7. HTC Droid Incredible Dual LED FLash Replacement: passo 7, immagine 1 di 1
    • The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
  8. HTC Droid Incredible Dual LED FLash Replacement: passo 8, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement: passo 8, immagine 2 di 2
    • Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver.
    • Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
  9. HTC Droid Incredible Dual LED FLash Replacement: passo 9, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement: passo 9, immagine 2 di 2
    • Loosen the clips on the side next to the camera using the method described in the previous step.
  10. HTC Droid Incredible Dual LED FLash Replacement: passo 10, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement: passo 10, immagine 2 di 2
    • Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
  11. HTC Droid Incredible Dual LED FLash Replacement: passo 11, immagine 1 di 3 HTC Droid Incredible Dual LED FLash Replacement: passo 11, immagine 2 di 3 HTC Droid Incredible Dual LED FLash Replacement: passo 11, immagine 3 di 3
    • Use the same technique to loosen the clip on the top of the phone.
    • You may need to gently lift the bottom of the rear inner frame to free this clip.
  12. HTC Droid Incredible Dual LED FLash Replacement: passo 12, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement: passo 12, immagine 2 di 2
    • Remove the rear inner frame.
  13. HTC Droid Incredible Dual LED FLash Replacement, Dual LED FLash: passo 13, immagine 1 di 1
    • Remove two #000 Phillips screws attaching the Dual LED Flash board to the Rear Inner Frame.
  14. HTC Droid Incredible Dual LED FLash Replacement: passo 14, immagine 1 di 2 HTC Droid Incredible Dual LED FLash Replacement: passo 14, immagine 2 di 2
    • Use a small flathead screwdriver to gently pry the dual LED flash board off the posts holding it to the rear inner frame.
    • Remove the dual LED flash board from the rear inner frame.
Conclusione
iFixit Membro di iFixit
Staff
135 Membri
16.767 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 944
