Introduzione
Use this guide to replace or upgrade the battery in your Droid Incredible.
Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
  • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
  • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
Aggiungi Commento
Remove the rear panel from the phone.
  • Remove the rear panel from the phone.
Aggiungi Commento
  • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
  • Lift the top of the battery up and remove the battery from the rear inner frame.
Aggiungi Commento
Conclusione
Andrew Optimus Goldberg
Membro da: 17/10/2009
383.966 Reputazione
412 Guide realizzate
iFixit Membro di iFixit
Community
107 Membri
6.499 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,242
