Introduzione
In addition to the possibility that the battery may be the reason why your phone is not charging, the charging port may also need to be replaced or tightened if loose. Ensure that the delicate parts of the phone revealed in the replacement procedure.
Parti
Nessuna parte richiesta.
Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
  • Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
Aggiungi Commento
Remove the battery after taking off the cover.
  • Remove the battery after taking off the cover.
Aggiungi Commento
  • Remove eight 4mm and one 5mm Torx screws.
This should be Step 3.
Tisha - Replica
  • Use a prying tool to pry off the midframe.
This should be Step 4.
Tisha - Replica
  • Remove the 4mm Torx screw holding the charging port to the phone.
This should be Step 5.
Tisha - Replica
  • Remove the silver bracket holding the charging port in place.
This should be Step 6.
Tisha - Replica
  • Use a prying tool to remove the charging port as shown.
This should be Step 7.
Tisha - Replica
Conclusione
Tevin
Membro da: 24/09/2014
639 Reputazione
4 Guide realizzate
USF Tampa, Team 15-1, Remmell Fall 2014 Membro di USF Tampa, Team 15-1, Remmell Fall 2014
USFT-REMMELL-F14S15G1
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 599
