Salta al contenuto principale
HTC Droid Incredible 4G LTE Display Assembly Replacement
Cosa ti serve
  1. HTC Droid Incredible 4G LTE Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
  2. HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the battery after taking off the cover.
  3. HTC Droid Incredible 4G LTE Display Assembly Replacement, Midframe: passo 3, immagine 1 di 1
    • Remove eight 4mm and one 5mm Torx screws.
  4. HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 4, immagine 1 di 2 HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 4, immagine 2 di 2
    • Use a prying tool to pry off the midframe.
  5. HTC Droid Incredible 4G LTE Display Assembly Replacement, Micro USB Port: passo 5, immagine 1 di 1
    • Remove the 4mm Torx screw holding the charging port to the phone.
  6. HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the silver bracket holding the charging port in place.
  7. HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 7, immagine 1 di 1
    • Use a prying tool to remove the charging port as shown.
  8. HTC Droid Incredible 4G LTE Display Assembly Replacement, Display Assembly: passo 8, immagine 1 di 3 HTC Droid Incredible 4G LTE Display Assembly Replacement, Display Assembly: passo 8, immagine 2 di 3 HTC Droid Incredible 4G LTE Display Assembly Replacement, Display Assembly: passo 8, immagine 3 di 3
    • Pry off and remove the back cover
  9. HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 9, immagine 1 di 1
    • Remove the 4mm Torx screw.
  10. HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 10, immagine 1 di 3 HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 10, immagine 2 di 3 HTC Droid Incredible 4G LTE Display Assembly Replacement: passo 10, immagine 3 di 3
    • Remove tabs holding the motherboard to the phone.
Conclusione
Altre 5 persone hanno completato questa guida.
Tevin
Membro da: 09/24/14
666 Reputazione
4 Guide realizzate
USF Tampa, Team 15-1, Remmell Fall 2014 Membro di USF Tampa, Team 15-1, Remmell Fall 2014
USFT-REMMELL-F14S15G1
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,050
