Salta al contenuto principale
HTC Droid Eris Battery Replacement
Cosa ti serve
  1. HTC Droid Eris Battery Replacement, Battery: passo 1, immagine 1 di 2 HTC Droid Eris Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Place the device on a flat surface with the headphone outlet facing you.
    • Place the tip of one of your fingers over the highlighted spot.
    • Next, pull the back cover upwards. If this feels difficult, use the spudger.
  2. HTC Droid Eris Battery Replacement: passo 2, immagine 1 di 2 HTC Droid Eris Battery Replacement: passo 2, immagine 2 di 2
    • Lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place.
    • With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you.
    • If the battery is not coming out with this technique, use the plastic opening tool.
Conclusione
SUNY Cortland, Team 1-2, Getto Spring 2013 Membro di SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 767
