Salta al contenuto principale
HTC Droid DNA Rear-Facing Camera Replacement
Cosa ti serve
  1. HTC Droid DNA Rear-Facing Camera Replacement, Remove the SIM Card Tray: passo 1, immagine 1 di 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  2. HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: passo 2, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: passo 2, immagine 2 di 2
    • Pull out the SIM Card Tray with your fingers.
  3. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: passo 3, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: passo 3, immagine 2 di 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
  4. HTC Droid DNA Rear-Facing Camera Replacement, Pull the Casing Apart: passo 4, immagine 1 di 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
  5. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Tape: passo 5, immagine 1 di 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
  6. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
  7. HTC Droid DNA Rear-Facing Camera Replacement: passo 7, immagine 1 di 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
  8. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Void Screw: passo 8, immagine 1 di 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
  9. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screw Retaining Bracket: passo 9, immagine 1 di 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
  10. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Connector Screws: passo 10, immagine 1 di 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
  11. HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: passo 11, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: passo 11, immagine 2 di 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  12. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: passo 12, immagine 1 di 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
  13. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: passo 13, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: passo 13, immagine 2 di 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  14. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: passo 14, immagine 1 di 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
  15. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: passo 15, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: passo 15, immagine 2 di 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  16. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: passo 16, immagine 1 di 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
  17. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: passo 17, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: passo 17, immagine 2 di 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
  18. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: passo 18, immagine 1 di 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
  19. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: passo 19, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: passo 19, immagine 2 di 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
  20. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Small Ribbon Connector: passo 20, immagine 1 di 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
  21. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Wire: passo 21, immagine 1 di 1
    • Remove the long black wire on the left of the motherboard.
  22. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Two Black Wires: passo 22, immagine 1 di 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
  23. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screws: passo 23, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
  24. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: passo 24, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: passo 24, immagine 2 di 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
  25. HTC Droid DNA Rear-Facing Camera Replacement, Remove Screws: passo 25, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
  26. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: passo 26, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: passo 26, immagine 2 di 2
    • Use the pry tool along the bottom and sides of the camera board to loosen the adhesive.
    • The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
  27. HTC Droid DNA Rear-Facing Camera Replacement, Remove Camera Board: passo 27, immagine 1 di 1
    • Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
  28. HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: passo 28, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: passo 28, immagine 2 di 2
    • Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board.
  29. HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: passo 29, immagine 1 di 2 HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: passo 29, immagine 2 di 2
    • Use your tweezers to gently flip the white connector board into the upright position.
  30. HTC Droid DNA Rear-Facing Camera Replacement, Remove Rear-Facing Camera: passo 30, immagine 1 di 1
    • Use your tweezers to remove the rear-facing camera from the camera board.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 4-43, Amido Fall 2014 Membro di Cal Poly, Team 4-43, Amido Fall 2014
CPSU-AMIDO-F14S4G43
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,287
