Salta al contenuto principale
HTC Desire 816 Top Speaker Replacement
Cosa ti serve
  1. HTC Desire 816 Top Speaker Replacement, Top Speaker: passo 1, immagine 1 di 1
    • Using the T5 screw driver, unscrew all of the screws that are holding down the black plastic casing.
  2. HTC Desire 816 Top Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the black plastics casing surrounding the motherboard with a plastic opening tool.
  3. HTC Desire 816 Top Speaker Replacement: passo 3, immagine 1 di 1
    • Using the PH000 screwdriver head, unscrew the screw that is holding down the motherboard. It is located on the left side of the motherboard.
  4. HTC Desire 816 Top Speaker Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers disconnect the battery from the motherboard so that the motherboard could later be removed from the device.
  5. HTC Desire 816 Top Speaker Replacement: passo 5, immagine 1 di 1
    • Once you have flipped the motherboard over, you should be able to locate the speaker at the top of the phone.
  6. HTC Desire 816 Top Speaker Replacement: passo 6, immagine 1 di 1
    • Remove top speaker gently with a pair of tweezers.
    • The speaker is also connected to a flat black plastic casing which will also be removed as you lift the speaker
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,287
