Salta al contenuto principale
HTC Desire 700 Dual Sim Rear Panel Replacement
Cosa ti serve
  1. HTC Desire 700 Dual Sim Rear Panel Replacement, Back Cover: passo 1, immagine 1 di 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Rear Panel Replacement, Removing Battery: passo 2, immagine 1 di 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Rear Panel Replacement, Remove 8 Torx Screws: passo 3, immagine 1 di 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Rear Panel Replacement, Prying Off Rear Panel: passo 4, immagine 1 di 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
Conclusione
Steven Pate
Membro da: 09/23/14
191 Reputazione
7 Guide realizzate
USF Tampa, Team 9-3, Blackwell Fall 2014 Membro di USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,380
