Salta al contenuto principale
HTC Desire 700 Dual Sim Motherboard Replacement
Cosa ti serve
  1. HTC Desire 700 Dual Sim Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Motherboard Replacement, Removing Battery: passo 2, immagine 1 di 1
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Motherboard Replacement, Remove 8 Torx Screws: passo 3, immagine 1 di 1
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Motherboard Replacement, Prying Off Rear Panel: passo 4, immagine 1 di 1
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. HTC Desire 700 Dual Sim Motherboard Replacement, Disconnect Vibrator Wire: passo 6, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. HTC Desire 700 Dual Sim Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove volume control button ribbon with tweezers.
  8. HTC Desire 700 Dual Sim Motherboard Replacement: passo 8, immagine 1 di 1
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. HTC Desire 700 Dual Sim Motherboard Replacement: passo 9, immagine 1 di 1
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
Conclusione
Altre 2 persone hanno completato questa guida.
Steven Pate
Membro da: 09/23/14
191 Reputazione
7 Guide realizzate
USF Tampa, Team 9-3, Blackwell Fall 2014 Membro di USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,801
