Salta al contenuto principale
HTC Desire 626s Backplate Replacement
Cosa ti serve
  1. HTC Desire 626s Backplate Replacement, Backplate: passo 1, immagine 1 di 3 HTC Desire 626s Backplate Replacement, Backplate: passo 1, immagine 2 di 3 HTC Desire 626s Backplate Replacement, Backplate: passo 1, immagine 3 di 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Backplate Replacement: passo 2, immagine 1 di 2 HTC Desire 626s Backplate Replacement: passo 2, immagine 2 di 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Backplate Replacement: passo 3, immagine 1 di 2 HTC Desire 626s Backplate Replacement: passo 3, immagine 2 di 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 262
