Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Has your HTC Desire 610 stopped charging and you know it's not a battery or charging cord issue? Follow these steps to replace a faulty charging port in an HTC Desire 610. In this guide you will learn how to take off the back, unscrew the circuit cover, and safely take out the charging port to replace with a new one.
  1. Using a plastic opening tool, take off the back cover of the phone. Using a plastic opening tool, take off the back cover of the phone. Using a plastic opening tool, take off the back cover of the phone.
    • Using a plastic opening tool, take off the back cover of the phone.
  2. Remove the four black 4mm torx screws using the Torx T5 bit.
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. APRI TUTTE LE SCHEDE
    Kit espansione RAM per Mac
    Acquista Kit
    Abbastanza RAM
    Per tutte le schede
    Acquista Kit
  6. Remove the black plastic circuit cover using a plastic opening tool.
    • Remove the black plastic circuit cover using a plastic opening tool.
  7. Remove the 4mm black Torx screw using a Torx T5 screwdriver.
    • Remove the 4mm black Torx screw using a Torx T5 screwdriver.
  8. Using a pair of tweezers, disconnect the antenna wire.
    • Using a pair of tweezers, disconnect the antenna wire.
  9. Peel back the gray adhesive strip using the precision tweezers. Peel back the gray adhesive strip using the precision tweezers. Peel back the gray adhesive strip using the precision tweezers.
    • Peel back the gray adhesive strip using the precision tweezers.
  10. Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
    • Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
  11. Pry up the circuit board and pull it out using a pair of precision tweezers. Pry up the circuit board and pull it out using a pair of precision tweezers. Pry up the circuit board and pull it out using a pair of precision tweezers.
    • Pry up the circuit board and pull it out using a pair of precision tweezers.
  12. Remove the loud speaker using a pair of precision tweezers. The loud speaker is attached with adhesive and may require more force than expected to remove. The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
    • Remove the loud speaker using a pair of precision tweezers.
    • The loud speaker is attached with adhesive and may require more force than expected to remove.
    • The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
Conclusione
Kaycee Hammond
Membro da: 11/02/2017
249 Reputazione
2 Guide realizzate
IUPUI, Team S1-G1, Wilson Spring 2017 Membro di IUPUI, Team S1-G1, Wilson Spring 2017
IUPUI-WILSON-S17S1G1
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 991
