Salta al contenuto principale
HTC Desire 530 Micro USB Port Replacement
Cosa ti serve
  1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: passo 1, immagine 1 di 1
    • Remove the four 1.2mm screws in each corner.
    • Use the suction cup and plastic opening tool to pry the screen from the body.
  2. HTC Desire 530 Micro USB Port Replacement: passo 2, immagine 1 di 1
    • Gently pry the battery up at these three spots, and disconnect the power cables attached.
  3. HTC Desire 530 Micro USB Port Replacement: passo 3, immagine 1 di 1
    • You can then fold the battery back like so, and that will give you access to the screw.
  4. HTC Desire 530 Micro USB Port Replacement: passo 4, immagine 1 di 1
    • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
  5. HTC Desire 530 Micro USB Port Replacement: passo 5, immagine 1 di 1
    • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
  6. HTC Desire 530 Micro USB Port Replacement: passo 6, immagine 1 di 1
    • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
Conclusione
UMASSD-PEAK-F18S3G2 Membro di UMASSD-PEAK-F18S3G2
Community
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 643
