Salta al contenuto principale
HTC Amaze Motherboard Replacement
Cosa ti serve
  1. HTC Amaze Motherboard Replacement, Battery: passo 1, immagine 1 di 2 HTC Amaze Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
  2. HTC Amaze Motherboard Replacement: passo 2, immagine 1 di 1
    • Once you locate the battery, look for a notch below it.
    • Gently insert your fingernails into the notch.
    • Lift the battery out of its recess.
  3. HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: passo 3, immagine 1 di 3 HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: passo 3, immagine 2 di 3 HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: passo 3, immagine 3 di 3
    • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
    • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
  4. HTC Amaze Motherboard Replacement: passo 4, immagine 1 di 3 HTC Amaze Motherboard Replacement: passo 4, immagine 2 di 3 HTC Amaze Motherboard Replacement: passo 4, immagine 3 di 3
    • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
    • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
  5. HTC Amaze Motherboard Replacement: passo 5, immagine 1 di 2 HTC Amaze Motherboard Replacement: passo 5, immagine 2 di 2
    • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
  6. HTC Amaze Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 HTC Amaze Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 HTC Amaze Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Locate and remove the Phillips J000 screw.
  7. HTC Amaze Motherboard Replacement: passo 7, immagine 1 di 2 HTC Amaze Motherboard Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the power supply from the motherboard by gently pulling the end of the black wire with the precision tweezers.
  8. HTC Amaze Motherboard Replacement: passo 8, immagine 1 di 3 HTC Amaze Motherboard Replacement: passo 8, immagine 2 di 3 HTC Amaze Motherboard Replacement: passo 8, immagine 3 di 3
    • First, gently lift the black strip by pulling. It will take a little force and then it will disconnect.
    • Next remove the yellow mylar tape using the precision tweezers.
  9. HTC Amaze Motherboard Replacement: passo 9, immagine 1 di 3 HTC Amaze Motherboard Replacement: passo 9, immagine 2 di 3 HTC Amaze Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the jawbone connector that was under the mylar tape by gently pulling with the precision tweezers.
    • Now gently pull the motherboard away from its housing. You'll now have access to the bottom side of the motherboard.
  10. HTC Amaze Motherboard Replacement: passo 10, immagine 1 di 3 HTC Amaze Motherboard Replacement: passo 10, immagine 2 di 3 HTC Amaze Motherboard Replacement: passo 10, immagine 3 di 3
    • Locate a second jawbone connector covered by mylar tape at the bottom of the back of the motherboard.
    • Remove the tape by pulling gently with the precision tweezers.
    • Remove the jawbone connector with the precision tweezers.
  11. HTC Amaze Motherboard Replacement: passo 11, immagine 1 di 2 HTC Amaze Motherboard Replacement: passo 11, immagine 2 di 2
    • Carefully pull the motherboard out of its recess.
Conclusione
Altre 2 persone hanno completato questa guida.
Akshat Shah
Membro da: 09/26/16
368 Reputazione
3 Guide realizzate
USF Tampa, Team 16-3, Eyestone Fall 2016 Membro di USF Tampa, Team 16-3, Eyestone Fall 2016
USFT-EYESTONE-F16S16G3
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 534
