Introduzione
This guide will show how to remove the HTC Amaze's front facing camera by accessing it through the rear of the phone.
Cosa ti serve
Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
Locate the camera at the top right of the interior side of the motherboard, and remove the tape holding its connector in place. Peel back the tape using the precision tweezers
While holding the tape away, gently lift the camera up with the precision tweezers.
