Salta al contenuto principale
HTC 7 Surround Camera Replacement
Cosa ti serve
  1. HTC 7 Surround Camera Replacement, Back Case: passo 1, immagine 1 di 2 HTC 7 Surround Camera Replacement, Back Case: passo 1, immagine 2 di 2
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC 7 Surround Camera Replacement: passo 2, immagine 1 di 3 HTC 7 Surround Camera Replacement: passo 2, immagine 2 di 3 HTC 7 Surround Camera Replacement: passo 2, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC 7 Surround Camera Replacement: passo 3, immagine 1 di 1
    • Separate the screen and back cover with the opening tool.
  4. HTC 7 Surround Camera Replacement, Rear Camera: passo 4, immagine 1 di 1
    • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
    • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 152
