Salta al contenuto principale
HP17-x116dx Fan Replacement
Cosa ti serve
  1. HP17-x116dx Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your computer before starting. Place the back of your computer face up to ensure you are facing the battery.
  2. HP17-x116dx Fan Replacement: passo 2, immagine 1 di 2 HP17-x116dx Fan Replacement: passo 2, immagine 2 di 2
    • Find the battery latches.
    • Slide the latches towards the center of the device.
  3. HP17-x116dx Fan Replacement: passo 3, immagine 1 di 2 HP17-x116dx Fan Replacement: passo 3, immagine 2 di 2
    • Remove the old battery by pulling it towards you. Replace the old battery with the new one and follow these steps in reverse order to reassemble your device.
  4. HP17-x116dx Fan Replacement, Fan: passo 4, immagine 1 di 2 HP17-x116dx Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Remove the fourteen 8 mm screws with the Phillips #1 screwdriver.
  5. HP17-x116dx Fan Replacement: passo 5, immagine 1 di 2 HP17-x116dx Fan Replacement: passo 5, immagine 2 di 2
    • Once the screws are removed, carefully remove the CD player port.
  6. HP17-x116dx Fan Replacement: passo 6, immagine 1 di 2 HP17-x116dx Fan Replacement: passo 6, immagine 2 di 2
    • Once you have removed the CD player port, use the spudger tool to carefully remove the back panel.
  7. HP17-x116dx Fan Replacement: passo 7, immagine 1 di 1
    • Once you remove the back panel you will see your fan on the bottom left side of your laptop.
  8. HP17-x116dx Fan Replacement: passo 8, immagine 1 di 3 HP17-x116dx Fan Replacement: passo 8, immagine 2 di 3 HP17-x116dx Fan Replacement: passo 8, immagine 3 di 3
    • To remove the fan, start by unplugging the fan from the motherboard.
  9. HP17-x116dx Fan Replacement: passo 9, immagine 1 di 3 HP17-x116dx Fan Replacement: passo 9, immagine 2 di 3 HP17-x116dx Fan Replacement: passo 9, immagine 3 di 3
    • Once the fan is unplugged from the motherboard, remove the 6 mm screws with a Phillips #1 screwdriver that are connecting the fan to the laptop. Remove the fan.
  10. HP17-x116dx Fan Replacement: passo 10, immagine 1 di 1
    • Once the fan is removed, you will see the hot plate that transfers the heat from the laptop to the fan. You will need to add thermal paste to the hot plate before placing your replacement fan back on.
  11. HP17-x116dx Fan Replacement: passo 11, immagine 1 di 1
    • Once you have placed your thermal paste on the hot plate, take your replacement fan and place it back where the old fan was. To reassemble your laptop, follow these steps in reverse order.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Hola, se le puede instalar una memoria optane a éste modelo?
Henry - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,316
