Introduzione
If the CPU fan becomes to filled with dust or stops spinning, it must be replaced immediately. If it is not replaced then the CPU or motherboard can become damaged and cause the computer to be unbootable
Cosa ti serve
Lay the tower down carefully on its right side, with the vents pointing up.
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
Altre 2 persone hanno completato questa guida.
