Salta al contenuto principale
HP w2216h Power Button Replacement
Cosa ti serve
  1. HP w2216h Power Button Replacement, Power Button: passo 1, immagine 1 di 3 HP w2216h Power Button Replacement, Power Button: passo 1, immagine 2 di 3 HP w2216h Power Button Replacement, Power Button: passo 1, immagine 3 di 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: passo 2, immagine 1 di 1
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: passo 3, immagine 1 di 1
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
Conclusione
Altre 2 persone hanno completato questa guida.
Sadeq Taha
Membro da: 03/25/16
219 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 594
