Salta al contenuto principale
HP w2216h Control Buttons Replacement
Cosa ti serve
  1. HP w2216h Control Buttons Replacement, Control Buttons: passo 1, immagine 1 di 1
    • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
    • Remove the four 12 mm Phillips #000 screws on the back panel.
  2. HP w2216h Control Buttons Replacement: passo 2, immagine 1 di 2 HP w2216h Control Buttons Replacement: passo 2, immagine 2 di 2
    • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
    • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
    • Stand will easily pull off.
  3. HP w2216h Control Buttons Replacement: passo 3, immagine 1 di 3 HP w2216h Control Buttons Replacement: passo 3, immagine 2 di 3 HP w2216h Control Buttons Replacement: passo 3, immagine 3 di 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  4. HP w2216h Control Buttons Replacement: passo 4, immagine 1 di 1
    • Lift the screen assembly from the plastic housing from the corners.
  5. HP w2216h Control Buttons Replacement: passo 5, immagine 1 di 1
    • Remove the plastic buttons from the contacts
  6. HP w2216h Control Buttons Replacement: passo 6, immagine 1 di 2 HP w2216h Control Buttons Replacement: passo 6, immagine 2 di 2
    • Remove the wire connecting the contacts to the screen assembly.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 556
