Introduzione
The motherboard is the component that connects all the parts of the computer together either through wire connections or direct integration on the the board itself.
Cosa ti serve
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
Using your right hand, grip the CD drive and lift it up to a 90 degree position.
Using your right index finger, press the tab with the green sticker located underneath the power supply.
While pressing the tab, lift up the power supply the same way you lifted up the optical drive.
Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
Repeat the same process to remove the internal card power cable.
This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
Pull out the tab with the green sticker using your index finger.
If not, grasp the necessary cables with your hand and pull the cables straight out.
Using a Torx-Security T-15 screw driver, loosen the screws a little at a time evenly on each screw (process described below):
This process is done by slightly unscrewing a screw at one corner and moving to the screw at the diagonal corner next to unscrew slightly.
Then move to the opposite corners and repeat the process.
Continue until all of the screw are completely removed.
Remove the 7 screws surrounding the edges of the motherboard using a Torx-Security T-15 screw driver to unscrew each screw counterclockwise.
Altre 6 persone hanno completato questa guida.
