Salta al contenuto principale
HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: passo 1, immagine 1 di 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: passo 2, immagine 1 di 2 HP rp5700 Cover Removal Replacement: passo 2, immagine 2 di 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Cover Removal Replacement: passo 3, immagine 1 di 3 HP rp5700 Cover Removal Replacement: passo 3, immagine 2 di 3 HP rp5700 Cover Removal Replacement: passo 3, immagine 3 di 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
Conclusione
Altre 11 persone hanno completato questa guida.
Alyssa Briones
Membro da: 01/21/14
1.699 Reputazione
9 Guide realizzate
Cal Poly, Team 6-23, Maness Winter 2014 Membro di Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 86
Tutti i Tempi: 21,520
