Salta al contenuto principale
HP iPAQ H2200 Joypad Replacement
Cosa ti serve
  1. HP iPAQ H2200 Joypad Replacement, Battery: passo 1, immagine 1 di 1
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 Joypad Replacement: passo 2, immagine 1 di 2 HP iPAQ H2200 Joypad Replacement: passo 2, immagine 2 di 2
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 Joypad Replacement, Main Board: passo 3, immagine 1 di 1
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 Joypad Replacement: passo 4, immagine 1 di 1
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 Joypad Replacement: passo 5, immagine 1 di 1
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 Joypad Replacement: passo 6, immagine 1 di 3 HP iPAQ H2200 Joypad Replacement: passo 6, immagine 2 di 3 HP iPAQ H2200 Joypad Replacement: passo 6, immagine 3 di 3
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 Joypad Replacement: passo 7, immagine 1 di 2 HP iPAQ H2200 Joypad Replacement: passo 7, immagine 2 di 2
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 Joypad Replacement: passo 8, immagine 1 di 1
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 Joypad Replacement: passo 9, immagine 1 di 1
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 Joypad Replacement: passo 10, immagine 1 di 1
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 Joypad Replacement: passo 11, immagine 1 di 1
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 Joypad Replacement, Joypad: passo 12, immagine 1 di 1
    • Press on the four joypad tabs on the back, and push it through and out the front.
  13. HP iPAQ H2200 Joypad Replacement: passo 13, immagine 1 di 1
    • Push the new joypad through the hole; the tabs will lock it into place.
Conclusione
Tyler Andrews
Membro da: 01/13/10
209 Reputazione
5 Guide realizzate
Cal Poly, Team 4-12, Forte Winter 2010 Membro di Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 3,043
