Salta al contenuto principale
HP eStation Zeen Battery Replacement
Cosa ti serve
  1. HP eStation Zeen Battery Replacement, Battery: passo 1, immagine 1 di 3 HP eStation Zeen Battery Replacement, Battery: passo 1, immagine 2 di 3 HP eStation Zeen Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the screw caps using a metal spudger.
    • Remove the four 6mm screws using a Phillips #0 screwdriver.
  2. HP eStation Zeen Battery Replacement: passo 2, immagine 1 di 3 HP eStation Zeen Battery Replacement: passo 2, immagine 2 di 3 HP eStation Zeen Battery Replacement: passo 2, immagine 3 di 3
    • Unclip each side by inserting a plastic opening tool and slide it along edges.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery clip with a plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Battery Replacement: passo 4, immagine 1 di 2 HP eStation Zeen Battery Replacement: passo 4, immagine 2 di 2
    • Remove the battery using the plastic opening tool.
    • There is glue holding the battery down so it will require some effort.
Conclusione
Altre 6 persone hanno completato questa guida.
dalton hale
Membro da: 09/26/16
503 Reputazione
4 Guide realizzate
USF Tampa, Team 16-4, Eyestone Fall 2016 Membro di USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Membri
10 Guide realizzate
3 Commenti
I did research and heard of this website carrying this battery, but HP says it is not replaceable. I say anything is possible. Here is the website for that battery for HP ZEEN for HP eStation C510.
http://www.batterybay.net/product-p/hpcs...
yf52170 - Replica
como eu compro uma bateria nova para o meu estation zeen???
Benedicto Junior - Replica
The battery is 100% absolutely replaceable. Not only that, every single Zeen ever made has a dead or minimally rechargeable OEM battery by now. They can be had on Amazon and other sources. I can’t remember the part # but it’s super easy to find by googling HP Zeen Battery or even using those words in an Amazon product search. Batteries are about 40 shipped. At this stage you have to decide for yourself if fixing this rapidly aging platform is worth it, I chose to scrap my set and get a 9025e used for less than 100. It’s modern, much better Wi-Fi that stays online and AirPrint that works every time. Yes it doesn’t have a giant screen but who cares nowadays with cheap iPads. The e station was ahead of its time and a very cool, unique product from HP’s bold days. Now they are far more conservative with designs and features but it’s not entirely a bad thing if you want rock solid stability which the Zeen set never had. That tablet was super cool though, and in an era when the iPad was still in its infancy!
darthdelirious - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,665
