Salta al contenuto principale
HP dv7-4065x Keyboard Replacement
  1. HP dv7-4065x Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove the battery from the laptop.
  2. HP dv7-4065x Keyboard Replacement: passo 2, immagine 1 di 1
    • Move the switch in the battery compartment.
  3. HP dv7-4065x Keyboard Replacement: passo 3, immagine 1 di 1
    • Carefully flip up the keyboard panel.
    • Don't pull far on the keyboard. It will still be connected to the laptop via ribbon cables.
  4. HP dv7-4065x Keyboard Replacement: passo 4, immagine 1 di 1
    • Lift the retaining flap on the keyboard cable ZIF connector.
    • Carefully pull the ribbon cable from its socket on the motherboard.
Conclusione
Un commento
First you need to unscrew 2 screws under the HDD cover
christo04 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,604
