Salta al contenuto principale
HP dv5-1125nr Disk Drive Replacement
Cosa ti serve
  1. HP dv5-1125nr Disk Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: passo 2, immagine 1 di 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: passo 3, immagine 1 di 2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: passo 3, immagine 2 di 2
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: passo 4, immagine 1 di 3 HP dv5-1125nr Disk Drive Replacement: passo 4, immagine 2 di 3 HP dv5-1125nr Disk Drive Replacement: passo 4, immagine 3 di 3
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Conclusione
Nick Loey
Membro da: 04/01/14
1.676 Reputazione
8 Guide realizzate
Cal Poly, Team 9-15, Regan Spring 2014 Membro di Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 733
