Salta al contenuto principale
HP dv5-1125nr Battery Replacement
Cosa ti serve
  1. HP dv5-1125nr Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
Conclusione
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
Altre 4 persone hanno completato questa guida.
Nick Loey
Membro da: 04/01/14
1.676 Reputazione
8 Guide realizzate
Cal Poly, Team 9-15, Regan Spring 2014 Membro di Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Membri
10 Guide realizzate
2 Commenti
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
glopam2013 - Replica
what is your return policy?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,195
