Salta al contenuto principale
HP ZBook 15 Optical Drive Replacement
Cosa ti serve
  1. HP ZBook 15 Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 HP ZBook 15 Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Optical Drive Replacement, Back Cover: passo 2, immagine 1 di 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 1
    • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
    • The screw does not come out all the way and stays attached to the computer.
  4. HP ZBook 15 Optical Drive Replacement: passo 4, immagine 1 di 3 HP ZBook 15 Optical Drive Replacement: passo 4, immagine 2 di 3 HP ZBook 15 Optical Drive Replacement: passo 4, immagine 3 di 3
    • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
    • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
Conclusione
Altre 4 persone hanno completato questa guida.
Grant Terris
Membro da: 01/30/15
2.828 Reputazione
12 Guide realizzate
Cal Poly, Team 8-43, Amido Winter 2015 Membro di Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membri
15 Guide realizzate
2 Commenti
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - Replica
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 27
Tutti i Tempi: 6,718
