Salta al contenuto principale
HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement
  1. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement, Access Panel: passo 1, immagine 1 di 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 2, immagine 1 di 2 HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 2, immagine 2 di 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 3, immagine 1 di 2 HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 3, immagine 2 di 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement, CPU Fan: passo 4, immagine 1 di 1
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
  5. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 5, immagine 1 di 1
    • Swing the fan upward, to a 90-degree angle.
  6. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 6, immagine 1 di 2 HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 6, immagine 2 di 2
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
  7. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 7, immagine 1 di 1
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
  8. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 8, immagine 1 di 1
    • Swing the fan up again and pull it out.
  9. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement, Power on/off Button and HDD Activity LED: passo 9, immagine 1 di 1
    • Remove HDD activity LED from retaining clip.
  10. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 10, immagine 1 di 1
    • Grab and lift the cable off of the motherboard and chassis.
  11. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 11, immagine 1 di 1
    • Pull the HDD activity LED out of the chassis.
  12. HP Z2 Mini G3 Power On/Off and HDD Activity LED Replacement: passo 12, immagine 1 di 1
    • Pull the cable from the motherboard to finish removing the component.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,415
