Salta al contenuto principale
HP Z2 Mini G3 Access Panel Replacement
  1. HP Z2 Mini G3 Access Panel Replacement, Access Panel: passo 1, immagine 1 di 1
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 Access Panel Replacement: passo 2, immagine 1 di 2 HP Z2 Mini G3 Access Panel Replacement: passo 2, immagine 2 di 2
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 Access Panel Replacement: passo 3, immagine 1 di 2 HP Z2 Mini G3 Access Panel Replacement: passo 3, immagine 2 di 2
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,073
