Salta al contenuto principale
HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement
Cosa ti serve
  1. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: passo 1, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: passo 1, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Batteries: passo 1, immagine 3 di 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: passo 2, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Shell: passo 2, immagine 2 di 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 3, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 3, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 3, immagine 3 di 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 4, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement: passo 4, immagine 2 di 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: passo 5, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: passo 5, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Trigger Replacement, Trigger: passo 5, immagine 3 di 3
    • Grasp the trigger with one hand while pushing against the outer wall of the shell.
    • Apply pressure, pulling the wall away from the trigger.
    • Remove the trigger starting from the freed edge.
    • The spring-rod assembly can easily come apart. Inserting the large end first during reassembly may make the process easier.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S18-G5, White Winter 2019 Membro di Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,777
