Salta al contenuto principale
HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad Replacement
Cosa ti serve
  1. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: passo 1, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: passo 1, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: passo 1, immagine 3 di 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
  2. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Shell: passo 2, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Shell: passo 2, immagine 2 di 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
  3. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 3, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 3, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 3, immagine 3 di 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
  4. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 4, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 4, immagine 2 di 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
  5. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Small Circuit Board: passo 5, immagine 1 di 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Small Circuit Board: passo 5, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
  6. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 6, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 6, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 6, immagine 3 di 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
  7. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: passo 7, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: passo 7, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: passo 7, immagine 3 di 3
    • Remove the two 6mm screws at the base of the rings using a Phillips #0 screwdriver.
    • Release the halo wire from the connector on the circuit board.
    • Pull the halo ring apart from the rest of the controller.
  8. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 8, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 8, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 8, immagine 3 di 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
  9. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 9, immagine 1 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 9, immagine 2 di 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: passo 9, immagine 3 di 3
    • Unclip one of the tabs on the underside of the touch pad.
    • Using a spudger, pop off the touch pad.
Conclusione
Cal Poly, Team S18-G5, White Winter 2019 Membro di Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 838
