Salta al contenuto principale
HP TouchSmart 15-r015dx Battery Replacement
  1. HP TouchSmart 15-r015dx Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your laptop.
    • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
    • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
  2. HP TouchSmart 15-r015dx Battery Replacement: passo 2, immagine 1 di 1
    • There are two battery release switches circled.
  3. HP TouchSmart 15-r015dx Battery Replacement: passo 3, immagine 1 di 1
    • slide release switches inward towards each other to release battery.
  4. HP TouchSmart 15-r015dx Battery Replacement: passo 4, immagine 1 di 1
    • after sliding the release switches, pull battery towards yourself to remove battery.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 16-4, Watkins Winter 2015 Membro di USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Membri
6 Guide realizzate
Un commento
I did all the steps but the laptop didn't turn on at all. I then unhooked the power, removed the new replacement battery, and plugged the power back in it turned on without the battery but it won't turn on with the new battery in it. What am I doing wrong? Thx for you time.
Sincerely, Don Mattia
ddavonn - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,200
